Video brigthness or color shift darker when exported from Indesign to PDF
COW Forums : Adobe InDesign
Rip Odebralski
on Sep 18, 2014 at 7:23:58 pm
Does any one know if there is a setting that I'm missing. When I export an Indesign document to interactive pdf(either F4V or MP4) they playback darker in the PDF file.
I Tested embedding the files directly into a PDF with acrobat and they play back fine, it's only when they are exported from Indesign that the color shift occurs. I prefer to use Indesign because there is more control over video handling then in Acrobat.
Dave Brubaker
Re: Video brigthness or color shift darker when exported from Indesign to PDF
on Apr 15, 2015 at 9:34:34 pm
Did you ever solve this issue? Just stumbled onto the problem myself. If you have any info I'd be grateful.
Rip Odebralski
on Apr 16, 2015 at 3:06:49 pm
Nope, and nobody has answered it either.
Dave Brubaker
on Apr 16, 2015 at 3:39:06 pm
Thanks. I'll dig a little deeper and and let you know what I find out. I have to solve this, so hopefully there's a solution.
