Indesign cannot save my file
COW Forums : Adobe InDesign
Nicki Marotta
on Mar 26, 2014 at 1:06:15 am
I have spent weeks and weeks doing a 70 page document and it has just suddenly decided not to save the file any more. the message i get is:
Cannot save "file name".
Please, is there anything i can do?
Matt Townley
Re: Indesign cannot save my file
on Apr 11, 2014 at 4:50:01 am
I'm assuming/hoping you have found the solution for this but if you haven't I hope it worked out ok for you. This does occasionally happen and the first time it happened to me I freaked out! However, there is a pretty decent work around so stay calm and hang in there - you'll get through it.
Here's what to do:
1. Go to FILE > EXPORT
2. Choose FORMAT > IDML
That will export a working and current version of your project.
BEFORE YOU QUIT - open the file that you just exported and test to make sure everything is ok.
If all is well, now save that as a proper InDesign file and then you should be good to go. You can quit and close the other file and should now have a working version that can be saved.
Juan Jesús Millo Dominguez
on May 8, 2014 at 11:00:35 pm
I've the same problem!
© 2018 All Rights Reserved
