Export to PDF results in "background task" error
COW Forums : Adobe InDesign
Janet Holmes
on Jul 23, 2012 at 2:38:02 pm
Never had this happen before -- exporting from InDesign CS5.5 to Adobe PDF causes this error message:
"1 problem (1 failure) was found with a background task:
Export [filename]"
I don't have a clue what actually happened or how to resolve it. Any help? The file itself is not terribly complicated, save for a lot of font changes.
Janet in Boise
Melissa Mayo
Re: Export to PDF results in "background task" error
on Jul 24, 2012 at 2:53:16 pm
Make the PDF again and see if you can click on the error message. It should give you a description of the error.
Melissa J. Mayo, ACE
