InDesign Preflight
COW Forums : Adobe InDesign
Jeff Cochran
InDesign Preflight
on May 25, 2012 at 3:26:14 pm
Hello,
I'm running a custom preflight profile in InDesign. The problem I have is, it's flagging Adobe Illustrator files that contain only vector objects as being low resolution (72dpi). Obviously, InDesign shouldn't be flagging the graphic at all.
Can anyone help me fix this?
Thanks in advance.
Jeff
Dwayne Smith
Re: InDesign Preflight
on May 27, 2012 at 9:59:34 am
G'day Jeff
Vector files CAN have a low resolution if you are using things like gradients or dropshadows or whatnot.
Open the file in Illustrator and go to Effect > Document Raster Effects Settings...
See if that fixes things
m.
Jeff Cochran
on May 29, 2012 at 2:02:31 pm
Hi Dwayne,
That fixed several of the problems. It seems to be flagging a gradient that was created in Illustrator as low res. Any tips for fixing that?
Thanks for the help. It's greatly appreciated.
Jeff
Jeff Cochran
http://www.jeffcochrandigitalartist.com/
