Tracking problem
COW Forums : Adobe InDesign
Jeff Cochran
Tracking problem
on Nov 3, 2011 at 7:41:12 pm
I'm having an issue when I kern or track copy in InDesign. When I try to track a line of text in the middle of a paragraph, often times InDesign will change the text above the line I'm working on (as in rolling part of the line down a line). Is there any way I can fix this so when I kern a line of text it doesn't change any text above the line I'm working on?
Thanks in advance.
Dwayne Smith
Re: Tracking problem
on Nov 8, 2011 at 9:45:43 am
In CS2 you would open your paragraph panel and choose Single Line Composer from the dropdown menu. This is a paragraph level preference, so you only need to have your cursor somewhere within the paragraph to change the composer preference.
I guess it's something similar in other versions too.
Hope that's what you're looking for.
© 2018 All Rights Reserved
