Interactive Page Curl Option
COW Forums : Adobe InDesign
Lisa Hurley
on Sep 18, 2011 at 1:50:10 am
Hello!
I have what would seem to be a very simple problem, but seeing how I've searched for a solution for several hours, and can't find anything, I'm at the end of my rope on this one.
I am attempting to export to swf, using the page curl option. This option appears in the "Preview Settings" box as the last step in exporting.
My problem is, that the option is completely grayed out, meaning, I cannot select the page curl option. Period.
I am new to Indesign, but have successfully exported a full document to regular pdf format with not problems. However, after experimenting a little, I noticed that NONE of the transitions were working.
So, I CAN export to swf, but when the document appears on the browswer, it shows the first page only, with no way to flip throught the pages.
This is CS5, by the way.
Do any of you have any ideas? Is there something I might be missing?
Thanks in advance!
Lisa
