Indesign Exporting PDF - Text Being separated despite individual text boxes.
COW Forums : Adobe InDesign
Jeff Schultz
on Aug 9, 2011 at 5:02:44 pm
I am exporting a job to be used as a template where customers can edit pictures and text. When I export the file it is randomly separating the text onto separate lines and I can't figure out why?!?
I have each area of text in its own text box and even tried them on separate layers.
But when I export the PDF the text is separated
Any Ideas?
Terry Mikkelsen
Re: Indesign Exporting PDF - Text Being separated despite individual text boxes.
on Aug 10, 2011 at 8:24:04 pm
This isn't something that I typically need to accomplish, so I don't have the exact answer. But I am wondering if you are using some custom tracking as then it would have to split up the text to maintain that spacing in the pdf.
Tech-T Productions
http://www.technical-t.com
Jeff Schultz
on Aug 10, 2011 at 8:36:36 pm
Nope nothing unusual. Just straight text in a text box.
I asked around on another forum, and they said INDD tries to get the spacing correct via kerning, and that causes the separated text.
I guess I have to switch it all the Illustrator and use it that way.
Terry Mikkelsen
on Aug 10, 2011 at 8:38:31 pm
Maybe trying switching between optical and metric kerning.
Tech-T Productions
