Layers from an Illustrator file
COW Forums : Adobe InDesign
Jeff Cochran
on Aug 3, 2011 at 8:10:12 pm
Hello,
I'm importing individual layers from an illusrator file using the the "Show Import Options" function in InDesign. I currently have 20 layers from the same .ai file imported as separated graphics. I recently opened the Illustrator file and made some changes.
Now, when I update the graphics in InDesign, instead of updating the graphic with only the layer I originally imported, it updates each file with every layer in the illustrator file.
Is there a way for me to have InDesign update just the layer?
Thanks in advance for the help.
Jeff
Dwayne Smith
Re: Layers from an Illustrator file
on Aug 8, 2011 at 2:52:44 am
G'day Jeff,
Yep, InDesign is a bit of a pain in that way. If you add, delete, or rename layers in your source file InDesign doesn't know how to handle your original Object Layer Options — so it imports all visible layers. If you just edit content on the various layers, you're fine — but make edits to the layers themselves and you got yourself a world or arrgh.
d.
