I want to design a booklet in InDesign CS5, and save it as a PDF.
COW Forums : Adobe InDesign
Sebastian Knight
on Mar 29, 2011 at 1:29:51 pm
I understand I can create a document in InDesign CS5, like a normal document. Then I understand there is a way to have InDesign CS5 create a booklet, I want to know how can I make it into a PDF?
As always thanks in advance for your reply,
Sebastian
Thank You in advance for taking the time to read and reply to my Post.
Sebastian
Terry Mikkelsen
Re: I want to design a booklet in InDesign CS5, and save it as a PDF.
on Apr 1, 2011 at 5:24:40 pm
I use CS3, so I can't say if there might be a more elegant way to do this in version 5.
But... I would use the "print booklet" command found in the file menu. Then instead of printing to an actual printer, I would print to the Adobe pdf printer or to postscript.
Tech-T Productions
http://www.technical-t.com
xavier khonje
on Apr 7, 2011 at 8:21:05 am
Actually thats the only I know, too
If you can imagine it, then you can do it
Sebastian Knight
on Apr 10, 2011 at 11:59:16 am
I am creating a 3 page, 2 sided 11" x 17" booklet, do I create the InDesign document with the 6 11" x 17" pages and the use the "print booklet" command in the file menu to create the booklet?
Thanks in advance for your reply,
Sebastian
Sebastian
