Text doesn't print stroke properly
COW Forums : Adobe InDesign
Warren Buchalter
on Mar 27, 2011 at 6:38:59 pm
I've created a Bluray wrap cover with Indesign CS5. It's 3 pages connected to each other corresponding to the back, spine and front cover. The text on the front cover is white with a black stroke. It looks perfect in the program. I don't have Win7 64 drivers for my printer. In order to print it I have to create a PDF choose the spread option, which I open in adobe reader in Virtual XP mode. The file still looks correct but when I print it out the left side of the stroke on each character is aligned properly but the the right side of the stroke is shifted to the left. As if the stroke was a small font size compared to the white type. Any ideas on what is causing the issue?
Terry Mikkelsen
Re: Text doesn't print stroke properly
on Mar 28, 2011 at 4:56:23 pm
Maybe try outlining the fonts prior to making the pdf. (Be sure to NOT save the Indy file, as the text is now not editable!)
Tech-T Productions
http://www.technical-t.com
