InDesign Magazine Document Setup
COW Forums : Adobe InDesign
Tom Sherer
on Jan 24, 2011 at 5:05:44 am
Am working on a 24-page magazine that will be saddle stitched. Been working for hours trying to get the document set up correctly, to no avail. I have a good amount of experience with InDesign, but not specifically with setting up the documents.
The specs I have to follow are as follows:
1. Flat Printer Spread Trim Size (Before being Trimmed): 11.625” H X 17” W
2. Flat Printer Spread Final Trim Size: (After being trimmed): 10.75” H X 16.375” W
3. Final Fold Size: (After being stitched): 10.75” H X 8.1875” W
4. Head Trim: 0.375”
5. Foot Trim: 0.5
6. Saddle-Stitcher Lip: 0.375”
7. Bleed: 0.125”
8. Total Face Trim: 0.5” (1/8” Bleed + 3/8” Lip)
In terms of the main document height and width, do I want to use the "before trim" or "after trim" numbers? Am I correct to use margins to set the head and foot trim? And I don't get at all what the saddle-stitcher lip is. Any guidance would be appreciated.
Thanks.
xavier Khonje
Re: InDesign Magazine Document Setup
on Jan 25, 2011 at 9:25:17 am
I work for a Magazine Publishing company. I would like to know which version of indesign you are using? as that might help, coz am using CS3 and some of those options are not available on mine.
Tom Sherer
on Jan 25, 2011 at 12:49:31 pm
I have CS3. I'm particularly perplexed by what/where the saddle stitch lip is.
xavier Khonje
on Jan 26, 2011 at 11:29:55 am
go to FILE-PRINT BOOKLET: the Dialog box that comes has stuff about saddle stitch depending on your packaging method you might need to specify or not.
