Text Wrap Issues
COW Forums : Adobe InDesign
Hilary Moore
Text Wrap Issues
on Jul 9, 2010 at 3:28:49 pm
Hopefully this will be an easy question to answer. I design a magazine and when I copy and paste text from Word into Indesign, I find that the text wraps sooner than it should-- leaving space on the right side of the column. I can correct it by putting soft returns in at the end of each paragraph (the lines jump into the correct place) but this seems like a silly thing to have to do. And, when my editor goes into the file to make changes, should he change one of those paragraphs, the spacing gets completely messed up. Anyone have a fix for this issue?
Terry Mikkelsen
Re: Text Wrap Issues
on Jul 20, 2010 at 7:29:50 pm
Did you try "paste without formatting"?
Tech-T Productions
http://www.technical-t.com
Hilary Moore
on Jul 21, 2010 at 12:28:18 pm
Thanks for your suggestion. Yes, I tried that and it didn't help. I also tried importing the text as an RTF and a few other tricks and nothing is making a difference. Surely someone else has run into the issue. Maybe it's a CS2 thing?
