Unintended automatic text frame columnation
COW Forums : Adobe InDesign
Kolja Kozelj
on Jun 22, 2010 at 2:29:39 pm
Everytime i paste some text on page or make a text frame, it automatically appears in 4 columns form. Its annoying, since i regularly have to open Text frame options and manually change it to desired number of columns.
Thank you very much!
Terry Mikkelsen
Re: Unintended automatic text frame columnation
on Jul 1, 2010 at 8:36:21 pm
I've never seen this before. Some have complained that when pasting the text it becomes in image (png) instead of editable text. The solution there was to create the text box first, place your I beam in the box and then paste.
Though this doesn't solve the problem of why it is doing this, it may be a work-around until you get more time to play with it.
Tech-T Productions
http://www.technical-t.com
Kolja Kozelj
on Jul 1, 2010 at 10:53:05 pm
Thanks for respond!
Some texts (in my case copied in Word) were set in raster when pasted directly to artboard. In my case, pasted text or new text box were 4 columned (and also had unintended text wrap and paragraph style).
In the meantime i found the solution. All those options were set without any assigned frame, “on dry”, and so became default options for every further frame. Reverse process solved the problem ...
