Layout Adjustment doesn’t work on text boxes!
COW Forums : Adobe InDesign
Radek Robos
on Feb 12, 2010 at 10:47:14 am
I have to resize a multiple (60+) pages document from B5 to A5. I have tried the Layout Adjustment command, but it did not sized the content of the text boxes. Does anybody know a solution for resizing a whole leaflet including the text flow and the paragraph layout?
I have tried both option for the Edit\preferences\General\when scaling command, but it did not worked…
The document has to stay editable, so the „create a pdf, and resize this” is not an optionL
Could it be a bug, as the original document was created in CS2, later opened modified and saved in CS3, and delivered to us? We haven’t got the original CS2 master, so I can’t compare it with the CS3 version document…
Kelly Johnson
Re: Layout Adjustment doesn’t work on text boxes!
on Feb 14, 2010 at 3:57:20 pm
Select all elements on a page, group, then resize. Your type will scale down so then you'll have to ungroup all and adjust the style sheet accordingly.
