Mail Merge using InDesign
COW Forums : Adobe InDesign
Renee Dreckman
on Feb 1, 2010 at 8:22:19 pm
I am trying to do a mail merge for a postcard that is 6 x 4.25 and I want to print these 4 up on an 11 x 17. How do I do the merge and get 4 different addresses to print on that sheet. When I do the multiples, I get the same name 4 up. Any ideas or suggestions?
Terry Mikkelsen
Re: Mail Merge using InDesign
on Feb 3, 2010 at 3:06:56 pm
It starts with the formatting of your source data. If you need it four-up, you need your data the same way.
Column 1 - Name Column 2 - Street Column 3 - City/State Column 4 - Zip Column 5 - Name(2) Column 6 - Street(2), etc.....
So if you do four-up on a sheet, you'll need four sets of data going across in your columns.
http://i99.photobucket.com/albums/l305/Technical_Terry/merge.gif
Tech-T Productions
http://www.technical-t.com
ps-None of my comments are meant to be gospel. Otherwise, I would write a book that provided all the cold, hard, fast answers that everyone assumes are out there. These are the things that I have found to work well with my shooting habits and workflow. Always try things out for yourself and deduce the best workflow for you.
daniel varner
on May 12, 2010 at 5:37:35 pm
Did you ever get an answer to your question
