Step and repeat linked text frames
COW Forums : Adobe InDesign
George Haberberger
on Feb 1, 2010 at 2:35:07 pm
I need to make a grid of 180 text frames. This is easy using step and repeat but I want them to be linked so that I can flow a list of names into the first one and have it continue to all the rest of the frames in the grid. Is it possible to step and repeat a text frame that is linked?
Terry Mikkelsen
Re: Step and repeat linked text frames
on Feb 3, 2010 at 3:10:40 pm
Not that I can find to do. I think that it (the program) would be confused as to which frame it should link to. I tried Step&Repeat, Copy&Paste, and Duplicate. No luck.
Tech-T Productions
http://www.technical-t.com
ps-None of my comments are meant to be gospel. Otherwise, I would write a book that provided all the cold, hard, fast answers that everyone assumes are out there. These are the things that I have found to work well with my shooting habits and workflow. Always try things out for yourself and deduce the best workflow for you.
