Printing Bigger than the paper
COW Forums : Adobe InDesign
Reuben Zuazua
on Aug 8, 2009 at 4:29:03 am
Try and explain
I own an Epson R2400 with 13x19 Sheets of Paper.
How can I setup to print a document that is 36x48.
I thought To build my project that size and hit print and it will just use the amount of pages it needs and i would have to piece the pages together. but i was wrong.
So What is the proper setup to print a document that is 36x48in using as many 13x19 paper to print it up.
Reuben Zuazua
After Hours Production
graFX Artist
indie@afterhoursproduction.com
Terry Mikkelsen
Re: Printing Bigger than the paper
on Aug 8, 2009 at 1:02:41 pm
Yes, you were right. Design at 36x48. When click print, choose the "setup" tab on the left and then click on "Tile" at the bottom right. Make sure you have the paper size set to 13x19. It will print guides to help you line up the sheets and then you paste together.
Tech-T Productions
http://www.technical-t.com
Reuben Zuazua
on Aug 8, 2009 at 2:37:19 pm
Thank you, i will give this a shot
Reuben Zuazua
graFX Artist
Reuben Zuazua
on Aug 20, 2009 at 6:36:36 pm
Did not work... Im printing with Preview and page 1 looks good, page 2 and 3 look like abstract art, then page 5 is ok, 6-7 then 8.. blah...
Its a PDF of a Cities map.. Kinko will not in large it.. I just want to be able to learn the area streets and back roads.... it will help me arrive faster (EMT/Firefighter).. oh well
thank you,
Reuben Zuazua
graFX Artist
louise Robinson
on Sep 7, 2009 at 8:24:42 am
Can you set size paper up as a custom size then tick scale to fit media when printing??? Lx
