Why is ID still adding 1 point in script
COW Forums : Adobe InDesign
Miroslav Hora
on May 12, 2009 at 1:12:39 pm
Hi folks!
I am quite new to scripting ID so here is first issue I can't get solved.
I wrote a js where the dialogue window pops up and asks for dimensions of a new rectangle to add. This new rectangle is created with exactly those values I've inserted in the dialogue but with 0.353(or one point)added. For example - If I would insert 10,10 into dialogue the produced rectangle would have 10.353, 10.353. Any Idea? Thx for advice
http://kreativec.com
Prague - CZ
Terry Mikkelsen
Re: Why is ID still adding 1 point in script
on May 15, 2009 at 12:41:47 am
There are stroke options which may be the problem. The options are to have the stroke "inside" the box, "centered" or "outside".
I know in CS3, if I draw a box that is 10 x 10 and then change the stroke option, it will change the overall dimension of the box.
Tech-T Productions
http://www.technical-t.com
