Using arrow key to move in small increments
COW Forums : Adobe InDesign
Lisa Howden
on May 7, 2009 at 7:43:24 pm
Greetings all,
Please forgive my ignorance, I've just moved over from Quark and I'm trying to get a handle on some of the basic commands.
In Quark, if you hold down the alt key while using the arrow key it will allow you to move in smaller increments.
Is there a way to do this in Indesign?
Thanks in advance for any help you can provide.
Terry Mikkelsen
Re: Using arrow key to move in small increments
on May 15, 2009 at 12:44:37 am
shift + arrow = 10x
arrow = x
cmd(mac) + shift + arrow = 1/10x
Since you said "alt", I assume you are on PC. Maybe try "ctrl" instead of "cmd".
Tech-T Productions
http://www.technical-t.com
Lisa Howden
on May 15, 2009 at 1:47:23 pm
Thanks Terry,
It works!
Lisa
Terry Mikkelsen
on May 15, 2009 at 6:59:23 pm
Also in your Indy Preferences (Unit & Increment), you can specify the "X" amount that an arrow press will move an object. (Keyboard Increments > Cursor Key:) The default is 1 point (~0.0139in).
Tech-T Productions
Terry Mikkelsen
on May 15, 2009 at 8:03:36 pm
One more thing, since you are moving from Quark, check out this link
http://www.peachpit.com/articles/article.aspx?p=1323250
Its an excerpt from a book about transitioning from Quark to Indy. Should provide some helpful insight.
Tech-T Productions
Lisa Howden
on May 15, 2009 at 8:08:27 pm
Thanks for the article - it was like reading my mail. I think I've worked passed being "frustrated".
Anyway, I really appreciate your help.
