How do I get out of the 'grab-hand' mode?
COW Forums : Adobe InDesign
Al Jubra
on Mar 19, 2009 at 5:00:18 pm
I just opened InDesign CS4 for the first time to create a document and make a master page (following a video tutorial).
Whatever I did it turned the cursor into a 'grab-hand' and I cannot find a way to go back to choosing the pointer to select things.
Can someone please advise me how to get the pointer back, thanks.
Terry Mikkelsen
Re: How do I get out of the 'grab-hand' mode?
on Mar 20, 2009 at 7:44:10 pm
I have CS3 so maybe your problem is more than I realize.
Solution 1 - click on black arrow in the toolbar
Solution 2 - press the "v" key
Possible Solution 3 - check that your keyboard is working correctly. If you hold down the space bar, you get the hand. Is that key stuck?
Tech-T Productions
http://www.technical-t.com
