Exporting PDF in Printing Pairs
COW Forums : Adobe InDesign
Daniel Cote
on Feb 28, 2009 at 9:59:03 pm
A while back I was just playing around practicing InDesign by creating a book. I liked the way it turned out, and actually want to get this printed now.
Here's the bad news. Since I had no intentions of printing it before, I designed it as facing pages. Is there a way to export as a PDF so the pages are set in their printed pairs (40_01, 02_39, 03_38, etc)?
My first solution was to turn off Spreads when exporting so the printer could pair the pages manually, but I'm only getting this printed at a local print shop which does not use any proofing software and wouldn't be able to work with those files.
If all else fails, I can just recreate the document using exported PDF pages to pair the pages, but if this can be done just by checking a box somewhere, that would be a tremendous help. I'm currently using CS3 if that helps at all.
Thanks all.
cecil Phillips-Rit hey
Re: Exporting PDF in Printing Pairs
on May 25, 2009 at 11:20:30 am
Didi you have any success in creating printer pairs in InDesign? You can create a booklet for printing directly but a pdf is not retained as far as I know.
kirk tabalotny
on Sep 6, 2009 at 5:20:18 am
you'll probably find your solution in this article:
http://www.tek-tips.com/viewthread.cfm?qid=1428025&page=3
Keep in mind the very last point - talk to your printer to find out what sort of duplexing technology they have. Printing a 'rough' version of your book at home, and taping the individual pages together to create a mock-up book is also a great idea - it helps ensure your printer understands exactly how the book is supposed to look when printed and bound (that way you can ensure they're on the same page as you. Get it?...)
kirk tabalotny
on Sep 6, 2009 at 5:48:17 am
... this article is even more useful (step-by-step guide)
