Translating Indesign Files
COW Forums : Adobe InDesign
José Cervantes
on Feb 10, 2009 at 4:04:00 pm
Hi!
I would like to translate Indesign files. Is there any possible way of doing this using Indesign to export the text?
It would be needed to:
- Indesign to export all the text with formatting
- Exporting would respect the text blocks. I.e. the blocks would have separate "tags" to identify the "position" in the page.
- Indesign to import the translated text, maintaining all the formatting.
Thanks in advance!
José Raeiro
Ron Lindeboom
Re: Translating Indesign Files
on Feb 12, 2009 at 7:02:55 pm
I know that Framemaker can do things like those you mention but I am not sure that InDesign has this ability at the moment.
Anyone here ever done these kinds of things in InDesign? Inquiring minds want to know.
Best regards,
Ron Lindeboom
Creativity is a type of learning process where the teacher and pupil are located in the same individual.
Marco Villar
on Jun 26, 2009 at 6:57:14 am
Don't know if you're still looking for an answer, but there are two ways of doing this. First you can use a script, InDesign comes with a number of built in scripts, including one that can export text. I think where it is varies by what version you're using. However if you plan to import the text after translating it I would not recommend this option since there is no free import script. Your other option would be to use a CAT Tool, there is a guide to using one to do this here:
http://heightstranslators.com/translating_adobe_frameMaker_and_indesign_fil...
Beware, you will probably need to adjust the text a little after reimporting, and if you're not using Across the general procedure remains the same from the InDesign point of view, save it as instructed.
Furio Incolto
Re: Translate InDesign file
on Aug 25, 2009 at 11:49:22 am
Because I want to export files for translation effetturne, I suggest you use the tool directly available from major software-assisted translation, As across, Sdl trados, STAR Transit, Etc.. Thus, Addition to safeguarding the layout and all the formatting attributes can operate in a working environment "perfect translation", Riparmiando time.
More information about translation tools are available at the following address: http://www.SOGET.net / it/traduzione/77/traduzione-assistita.
sasha ye
on Jan 9, 2010 at 6:51:44 am
You can export Indesign file as Indesign interchange (INX). Then use CAT tool (I use TM-database from http://yehongmei.narod.ru/) for translate.
Then import the translated file to Indesign. All text formating will be keep.
