Tag Structures
COW Forums : Adobe InDesign
Chris Batt
Tag Structures
on Dec 9, 2008 at 9:01:00 am
I am producing a large university prospectus that we are wanting to be accessible. When producing a pdf file, IndesignCS4 produces automatic tags, however when opened into Acrobat the tags are randomly numbered and are all over the place. I have then tried to apply my own tags manually and restructured them manually using the structure column. I did this by applying styles to tags and renaming the tags accordingly. A pdf was written but again the order of the structure from Indesign to Acrobat9 was lost and the tags were randomly numbered. Is there a way to set up tags in Indesign, structure the reading order and write a pdf so Acrobat will order the tags in the order they have been set up and so the page reads in the correct order?
Sorry if this seems long winded.
© 2018 All Rights Reserved
