Lost text line 'guides' in the text box
COW Forums : Adobe InDesign
Karma Forester
on Nov 13, 2008 at 11:35:27 am
I have managed to loose the text line guides (the blue little guide that shows the path/line the text is typed on) and I cannot remember how to get it back. In illustrator the control H command shows/hides the text bounding box and line guide, but in ID only the box is affected. It is especially annoying when you are trying to type text on a path, and the path is invisibele.
Please help.
Erica Gamet
Re: Lost text line 'guides' in the text box
on Nov 16, 2008 at 6:08:55 pm
Did you put the page into Preview mode (where no guides or non-printing items are showing up)? You'll need to make sure you're in Normal view mode and turn "Show Frame Edges" back on (View menu).
Erica Gamet
Digital Dimensions
http://www.digi-wizard.com/learn
"...for there is nothing either good or bad, but thinking makes it so."
Karma Forester
on Nov 17, 2008 at 8:07:07 am
Thanks for your reply erica. Nope, I'm not in preview mode... I figured it out though. I was mixing it up a bit with the illustrator interface - and then i figured out how to get gridlines back in individual textboxes so I think I am ok now. :)
