Imports are too large. Not resizing correctly
COW Forums : Adobe InDesign
Gabe Macias
on Aug 21, 2008 at 11:03:49 pm
I just received a copy of Design Suite CS3 at work, and I've been using InDesign (no more Quark. YAY!) to do our company fliers.
I built the frame & header for the front, created a new document and flipped/rearranged everything to be mirrored on the other side. Now I'm trying to import (using Place) the back document into the front so I can duplex print. However, whenever I import one into the other, the imported document is way larger than its original size. No matter how I resize it (each individual object, or group then resize), it loses a LOT of detail. I also tried copy/paste and got the exact same results.
I've tried using different settings in the import options, but nothing I do helps. Does anyone now how I can fix this? Or even a work-around that I can use.
© 2018 All Rights Reserved
