does inDesign like Leopard?
COW Forums : Adobe InDesign
Raymond Tuquero
on Jan 3, 2008 at 3:57:19 am
Is inDesign not working in Leopard? I haven't touch the software since I did the upgrade a month ago. I have been video editing, but now that I have to create a tri-fold I needed to go back to print designs. Well, to my surprise, inDesign kept closing out. Hmmm... I know that Flash and Acrobat reader do not work. well, until the update that Adobe will be doing this month sometime. I was just wondering.
-Raymond Tuquero-
Houston Editor
Tim Cole
Re: does inDesign like Leopard?
on Jan 3, 2008 at 5:30:34 am
Raymond, check out my InDesign Backchannel blog on
CS3 supports Leopard, but there can be issues, especially if you're on a PPC machine. There's a problem with Leopard's Nav Svcs code that can cause crashes on some systems when using dialogs that access the file system. It's far more common on PPC's than on Mactel boxes. If you're shutting down in a dialog box, that's probably the explanation.
~ Tim Cole
© 2018 All Rights Reserved
