URGENT - Pasting Problem
COW Forums : Adobe InDesign
Alexis Kyprianou
on Dec 7, 2007 at 9:00:03 am
Dear users of InDesign,
I have a strange problem and I need your urgent help.
When I cut/copy and then paste, the item I am copying does not constrain the dimensions it had before copying. It becomes really huge.
Is it a setting? the strange thing about it is that doesn't happen all the time.
I would appreciate your help a lot.
Thank you in advance,
Alexis Kyprianou
Jacki in Atlanta
Re: URGENT - Pasting Problem
on Dec 21, 2007 at 12:35:24 am
Are you copying from another place in that same document or from another doc? What version of InDesign?
If you do a search in your help menu on "clipboard preferences" or "paste with formatting" or "pasting text attributes" you will probably find what you need.
Alexis Kyprianou
on Dec 21, 2007 at 7:05:24 am
I am copying from the same document. I's a CS2 version and it happens whatever I copy, images, text etc. The help menu doesn't have any results under the phrases you mentioned. I am just copy-pasting. As I said before. the strange thing is that it doesn't happen all the time.
Thank you for your time anyway
