CS2 : bullet alignment
COW Forums : Adobe InDesign
Kevin Bath
on Nov 26, 2007 at 12:35:43 pm
Simple question - I hope - but been scratching my head for a while over this one.
Been playing with the paragraph styles for a while, but cannot find any way of bringing the secondary lines (i.e. if a single item on a bullet point list runs to more than one line) in, so they line up with the first line.
How do I control the tab/indent of these secondary lines?
Many thanks,
Susan Appler de los Rios
Re: CS2 : bullet alignment
on Oct 2, 2008 at 7:56:48 pm
Use the command backslash key after the space between bullet and text that follows. it will align all as long as you don't use a paragraph return between lines. You won't need to manually end lines until the next paragraph return.
© 2018 All Rights Reserved
