How do I create a 8.5" x 50" and tile print it so its spans 4-8.5" x 14" sheets
COW Forums : Adobe InDesign
Sebastian
on Sep 26, 2007 at 6:47:00 pm
I want to create a document that will be 8.5" x 50" that I have it printed on 4-8.5" x 14" sheets through my printer, which I then cut and tape together. How do I do this in InDesign CS?
Thanks in Advance for your reply,
Sebastian
Thank You in advance for taking the time to read and reply to my Post.
Sebastian
Mike Gondek
Re: How do I create a 8.5" x 50" and tile print it so its spans 4-8.5" x 14" sheets
on Sep 27, 2007 at 8:12:58 pm
2 reasons you need more that 4 pieces of paper to tile your job.
1) Most printers do not print to the edge of teh paper, because the gripper has to grip the paper without ink/varnish adn that is what keeps your printer clean form loose toner/ink.
2) You need overlap (.125" minimum), to register your prints against.
You will need 8 pieces of paper to do this. Now if you document was 8" x 40", you could then do it on 4 pieces of legal paper.
Sebastian
on Sep 27, 2007 at 11:34:29 pm
Thank you fo that, but how do I print a tiled document?
Sebastian
MIke Gondek
on Sep 28, 2007 at 12:16:00 am
file >> print
Choose setup underneath general on options at left
enable tile and set an overlap
