Typing on a path - help!
COW Forums : Adobe InDesign
ColleenMW
on Sep 26, 2007 at 1:47:23 am
Hello --
I am trying to type on a circlular path (I used the ellipse too) and as I type along the top 1/2 of the circle, it's fine. But I want the type along the bottom 1/2 to be right-side-up (not upside down, as it is now..)
That is, I'd like to BOTTOM
Mike Gondek
Re: Typing on a path - help!
on Sep 27, 2007 at 8:05:43 pm
1) Set you type on the bottom of the circle
2) Swithc to the selection tool
3) Look at the top of the circle for a small line(AKA: center bracket). Position your cursor over the center bracket until your cursor turns into an upside down T. Grab the center bracket and pull it to the opposite side of the line.
Your text will now be flipped.
