Compression Transparency Problem! sos!
COW Forums : Adobe InDesign
ThatFoxEleanor
on May 26, 2007 at 10:37:32 am
When i export from an InDesign to PDF for print, some of my shapes (solid colours) are transparent. They do not appear so in Indesign and should not when exported. I don't know what to alter to fix this.
Please please please suggest some options.
-the shapes in indesign are set to normal in the transparency window in indesign
-i think the problem is in compression?
Thank you,
~ eleanor
http://www.eleanor-rosenberg.com
Frank
Re: Compression Transparency Problem! sos!
on May 27, 2007 at 2:27:44 pm
Have checked you transparency flattening presets? If your fills are over other fills then maybe you need to have them 'overprint'.
Hope that helps.
