Picture box resizing...
COW Forums : Adobe InDesign
bilart
on Sep 27, 2006 at 4:45:10 pm
I want to resize my picture box by typing in th evalues for width and height, but I don't want to scale the image that's in it at the same time. I just want my box to expand or shrink. How do I do it? I constantly get this question from Quark 'switchers' and I cannot answer that.
Ekwoman
Re: Picture box resizing...
on Sep 28, 2006 at 2:14:10 pm
If you're typing the values in the Transform palette, you want to de-select Transform Content in the palette menu. If you're using the Scale Tool, de-select Scale Content. If you're entering the new values in the Control palette, you will also de-select the Transform Content option in the palette menu. Hope that helps!
Erica Gamet
Digital Dimensions
http://www.digi-wizard.com/learn
"...for there is nothing either good or bad, but thinking makes it so."
bilart
on Sep 29, 2006 at 3:08:40 pm
Thanks a lot! It helped!
Ekwoman
on Sep 30, 2006 at 7:22:48 pm
Glad I could help!
Erica Gamet
Digital Dimensions
