placing text in current style
COW Forums : Adobe InDesign
s!
by
on Jun 17, 2006 at 2:55:52 am
Hello -
Does anyone know how you place text with the current style? At the moment I'm placing text and the style defaults to times.
Thanks in advance!
thumbslinger
Re: placing text in current style
on Jun 20, 2006 at 11:36:09 pm
select an empty text frame and choose the style. Then place the text. It will keep all the bolding/italic and such but apply the font.
Also, set the main style font before drawing any text frame.
s!
by
on Jun 21, 2006 at 6:48:06 am
That makes a lot of sense. Thanks. Really should have worked that out myself. Been working the wrong way for months.
Ekwoman
on Jun 21, 2006 at 4:56:48 am
A couple of questions, first: are you placing type or copying and pasting? What program and format is the original text in? Are you using CS or CS2 of InDesign? Are you bringing text into a text frame with existing text or will starting each text frame from scratch work for you? Thanks...that should point us in the right direction to solve your issue.
