Stress of switching from Quark to InDesign
COW Forums : Adobe InDesign
Jim Morton
on Jun 4, 2006 at 1:54:46 pm
Man, I wish that InDesign used the same shortcuts that Quark uses. Why do companies have to have so many different ideas about what short-cut keys do?
Jim
cow
Ron Lindeboom
Re: Stress of switching from Quark to InDesign
on Jun 4, 2006 at 1:57:58 pm
Jim,
It's easy to do this...
Just go under the "Edit" menu and down at the bottom you will see "Keyboard Shortcuts" and inside it is a "Set" menu -- set it to Quark Xpress.
Voila.
Best regards,
Ron Lindeboom
Mike Gondek
on Jul 11, 2006 at 7:18:09 pm
I know what you mean. I recently started a job where they have quark, and am now saying why can't quark use the same keyboard shortcuts as InDesign.
After being to aggravated with Quark taking away features in 6 that use to be in 4 such as the Open Publisher (similar to edit original image in InDesign), I convinced them to buy InDesign. If I could only convert the 2 projects I inherited from Quaker to InDesign, but InDesign does not open Quark 6 and I have not utility to convert downwards in Quark. Well the printer will have to deal with making EPS files for each page so Goudy Bold does not bitmap on the PC.
