Scale stroke &/or outline stroke
COW Forums : Adobe InDesign
TJ
by
on May 19, 2006 at 4:08:42 am
Is there a way to scale the point size of the stroke when resizing like you can in Illustrator?
or to transform a thick stroke to outlines?
(ex: to turn a short line into a filled rectangle.)
Alex Salerno
Re: Scale stroke &/or outline stroke
on May 24, 2006 at 6:10:26 pm
Weird! The only way I could get line weight to rescale was only if the line was part of a group and then to scale with the Direct Selection tool using the command key (adding Shift is optional). This did not work when scaling the line object alone or when using the Free Transform tool!! Let me know.
Alex
