Struggling from PageMaker!
COW Forums : Adobe InDesign
Glenn Woiler
on May 18, 2006 at 6:46:25 pm
Can someone tell me how to make an object "non-printing"? This was fairly easy in PageMaker. But I am loosing it... trying to figure out what InDesign might call it and where it is found. A graphic artist here has never used that feature even though she is really good at what she does. So.... How can I make a line, or circle that I have created... visible but it won't print?
thanks... I know it must be simple... but I am being forced to move over to this new program. :)
Glenn
Alex Salerno
Re: Struggling from PageMaker!
on May 19, 2006 at 1:23:34 am
From the WIndows Menu select the Attributes pallett, then select "non-printing".
Note: such non-printing objects will not appear on screen in the preview mode.
Glenn Woiler
on May 24, 2006 at 5:16:20 pm
Thanks... that worked. Now... how to get a drop shadow on text? I see how to do it to an object... but not text??? ahhhh
Alex Salerno
on May 24, 2006 at 5:29:50 pm
Select the text box with the selection tool (NOT the Direct Selection Tool). Make sure the text box doe NOT have a fill assigned to it. Then (I use the object contextual menus) control-click (or right-click on PC) the text box and select Drop Shadow, etc.
The trick is to have no fill assigned to the box/frame.
Glenn Woiler
on May 24, 2006 at 8:24:39 pm
Thanks. I use PM 6.5 at home on a PC and PM 7.0 at work on a MAC but OS 9.x is a pain to use from OS X so they want me to get with it on InDesign. Lots of familiar things but other things are wierd. Thanks again. Glenn
Alex Salerno
on May 25, 2006 at 1:46:59 am
I am a Quark 6.5 convert who will not be upgrading to Quark7!
Glenn Woiler
on May 31, 2006 at 6:31:59 pm
Quark... hmmm... I have not used that since the mid 90's when we were testing Quark and pageMaker because we wanted to move away from... VENTURA!!!
