Custom Image Frames
COW Forums : Adobe InDesign
Russell Cory
Custom Image Frames
on May 5, 2006 at 3:11:09 pm
Hello, I am curious if there is a way to convert IllustratorCS paths into custom image frames in InDesignCS. I am trying to avoid having to re-draw shapes with the InDesign pen tool..
Alex Salerno
Re: Custom Image Frames
on May 9, 2006 at 7:59:59 pm
Copy path in Illustrator. Paste into InDesign document. Go under the Object menu>Content and select either Graphic or Text.
Russell Cory
on May 9, 2006 at 8:39:55 pm
Thank you, I will use it!
Ekwoman
on Jun 21, 2006 at 3:06:10 am
Remember: to copy from Illustrator and paste into InDesign, you must have your Illustrator prefs set to use AICB (in the File Handling & Clipboard pref) and also choose "preserve paths" for this to work. Keep in mind, this will not be a linked file once placed in InD, so any updates to the AI file would have to be re-copied and re-pasted.
