reflecting text/objects
COW Forums : Adobe InDesign
12thmonkey
on Apr 27, 2006 at 6:48:25 pm
i have created some rather complex type containers in indesign, and need to reflect them across their vertical axis. Is there a way that i can do this without also reflecting the type they contain? Or, can i reflect both, and then reflect the type back so it is right-reading? Any thoughts?
Thanks in advance!
Don't sweat the petty things
cowcow
Ron Lindeboom
Re: reflecting text/objects
on May 2, 2006 at 9:31:54 pm
Is it possible to see an example of what you are trying/want to do?
Can you send a copy of that page of your project so that I can see it?
I think I know what you are trying to do but am still not 100% sure.
Best regards,
Ron Lindeboom
ron@creativecow.net
12thmonkey
on May 2, 2006 at 9:37:35 pm
ron-
Thanks for the response. i actually already worked around it. i couldn't figure out how to do what i wanted, so i just recreated the type container as a shape, reflected that, then turned it into a type container. Took longer, since i had to do it a bunch of times
Mike Gondek
on Jul 11, 2006 at 7:46:04 pm
You would have to convert the text to outlines, then use the flip horizontal command in the transform palette flyout menu.
You can try fooling around with anchored objects, but I could not find anythnig there and converting to outlines seems to be the best solution(though I usually try to keep things editable whenever possible).
