Placing .PSD files - can you access the layers????
COW Forums : Adobe InDesign
Nick
by
on Nov 17, 2005 at 2:48:45 pm
Hi all,
I'm using InDesign CS2 in which i want to be able to import my .PSD file and access the layers in InDesign and adjust the placement/scale of those layers within the PSD? Can you do this??
As far as i can figure out, i can only turn off the visibility of the layers in Object>Object Layer Options!
I'm hoping there is a way to import a full .PSD file and manipulate the layers from within InDesign.
Any help would be great, much appreciated!
Best regards,
Nick.
bilart
Re: Placing .PSD files - can you access the layers????
on Feb 14, 2006 at 2:31:13 pm
No, you cant change layers. Only thing you can do is turn off layers visibility, cliping paths, and ICC profiles
