importing a publisher file into indesign
COW Forums : Adobe InDesign
Brian Peterson
on Jul 8, 2005 at 7:08:50 pm
I've got a document created in publisher that I would prefer to get into InDesign to use. Is there a way to open a publisher file or convert it to a usable format for manipulation in inDesign?
Thank
Brian Peterson
cow
Thumbslinger
Re: importing a publisher file into indesign
on Jul 11, 2005 at 3:00:18 am
I feel your pain. Publisher? whew... so shines the problem with the desktop revolution!
I'm not aware of any simple conversions.
However, I don't use many Microsoft products so I'm not sure how well Word, if at all, would convert the text itself.
Since any actual design will need to be redone in InDesign, perhaps you can just export the text as rich text format or even ascii from Publisher?
Or, if you can make a pdf from Publisher and import that into InDesign...
Sometimes opening a pdf within Acrobat first and saving will allow better friendliness within InDesign. Or even opening a pdf in Illustrator.
