Davinci resolve prores render duplicate frames
Rayjohn Tagayon
on May 23, 2018 at 11:29:14 am
Hi
Our client just got back to us saying itunes rejected our prores movie because of "consistent duplicate frames." My problem is I render these prores files from a DPX sequence which is also the same frame rate as the output fps I set.
If they give us 23.976 dpx sequence, I lay-in 5.1 audio then render a 23.976 prores file. I wonder where do these duplicate frames come from. Any ideas?
Shane Ross
Re: Davinci resolve prores render duplicate frames
on May 23, 2018 at 5:56:25 pm
Can you see these duplicate frames yourself? Is the source footage also 23.98? Or do you have 29.97 or other frame rate footage in your sequence?
Shane
Little Frog Post
