Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor with BM Intensity Shuttle
Adam Read
on Feb 23, 2017 at 4:41:50 pm
Hi
For some bizarre reason, my Intensity Shuttle is not outputting 1920 x 1080p (25fps) to the external monitor when using ANY of the Adobe sequence presets.
It is only outputting if I select 1080i 25fps (which to my knowledge means interlaced, which the file/sequence is not.
Can anyone shed any light on this?
I contacted Blackmagic and they said contact Adobe. I contacted Adobe, and guess what? - they said contact Blackmagic!
Thanks in advance
ADAM READ
Shane Ross
Re: Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor with BM Intensity Shuttle
on Feb 28, 2017 at 3:10:19 am
Your monitor might not be capable of 25p...only of receiving a 25i signal. 25i is fine... and while the SIGNAL getting to the monitor is interlaced, the footage will still be progressive.
Shane
Little Frog Post
