Advice for Ursa Mini Broadcast unit set-up
Sajawal Waseem
on Dec 28, 2016 at 6:51:39 pm
Hello Guys,
Im in the process of setting up a new broadcast unit for my studio using the Ursa Mini with B4 lens (via B4 adapter) and the blackmagic ursa studio viewfinder. Im new to the blackmagic environment and therefore have a few questions.
I apologise if these questions seem to be very simple.
I wanted to ask which SDI cable will be ideal for this set up? From what i learned from BM's website I see that a 3G SDI is recommended for 1080 video. Since im using a B4 lens and the TV standard is 1080, that is what I need. Can you guys recommend any good cables/manufacturer?
Also are there any guides available for setting up a broadcast unit with Ursa Mini? I came across Bob Zelin's post https://library.creativecow.net/zelin_bob/blackmagic_design_tv_studio/1 which is very helpful but if there is something out there focusing on the Ursa Mini, it would be great.
