Ultrastudio MIni Monitor does not show up in Applications
Hendrik Martz
on Oct 17, 2016 at 9:12:40 am
Hello,
I have the following problem:
I have connected the Ultrastudio Mini MOnitor to my iMac (Running yosemite) via a thunderbolt cable.
It gets recognized by the Blackmagic Desktop Software (10.8.1).
The Monitor (NEC P241W-Bk) stays black. It is connected to the mini monitor via a display port to hdmi converter cable. The display port shows no input signal.
The output signal is set to 1080psF25, although I tried several other settings.
The Mini Monitor shows up in resolve but doesn't output. Shows up in premiere, but doesn't output. It does not at all show up in fcpx as A/V Video out..
Thanx for helping..
#########Edit#########
Obviously it is my display port to hdmi adapter. Because if I plug the monitor directly into my apple hdmi to thunderbolt adapter, it does not work as well..
If I plug into DVI to Thunderbolt adapter, the monitor works perfectly
