Monitoring on non-retina Mbp
Hendrik Martz
on Oct 4, 2016 at 10:25:43 am
Hello,
i have the following question:
I have a 2012 non-retina MBP with one TB-port.
If I attach a TB Display, it would give me a 2nd display and an additional TB-Port.
Is it possible to attach a BMD Ultrastudio mini monitor with TB to that port and then monitor my PP and Avid Timelines on a 2n external display? Editing on TB Display and previewing and grading on that 2nd external display?
Has anybody tried that yet??
Thanx for an answer in advance..
Shane Ross
Re: Monitoring on non-retina Mbp
on Oct 4, 2016 at 10:32:59 pm
[Hendrik Martz] "Is it possible to attach a BMD Ultrastudio mini monitor with TB to that port and then monitor my PP and Avid Timelines on a 2n external display? "
Yes. TB has loop through, so you can go to a TB display, then out of that to an IO device. or to a hard drive, then monitor, then BMD card. It works.
[Hendrik Martz] " Editing on TB Display and previewing and grading on that 2nd external display?"
Yes. I've done that, and still do that. I have the exact computer you have. But my BMD device happens to have two TB ports, so I go to IT first, then the external monitor (older one that's DVI). But I still get my laptop monitor, external computer monitor for second UI display, and the BMD to production monitor.
Shane
Little Frog Post
Hendrik Martz
on Oct 6, 2016 at 6:48:24 am
Thanx for the reply.
What kind of BMD device you have, that has two TB outs??
Hendrik
Shane Ross
on Oct 6, 2016 at 6:51:36 am
The UltraStudio 4K and 4K extreme...the rack mount boxes...have two TB ports. They ALL should have them, to be honest..
Shane
Little Frog Post
