Ultrastudio 4K Thunderbolt2 - 4K Real time down converter?
Ricardo Tabosa
on Feb 26, 2016 at 3:58:15 pm
Hello,
I need to buy a I/O device to one of my video edit setup. After all the research i've made the Utrastudio 4K Thunderbolt2 is my 98% sure to be my choice.
I run Premiere or Final Cut on MacPro (late 2013) and my output monitor is a EIZO CX271 connected trough HDMI as second monitor (but I only use it as final output).
My work is mostly editing in 4K timelines from Sony FS7 MXF.
Question 01:
Does the Ultrastudio OUTPUT do real time down convert to 1080p HDMI?
That would save a lot of time not to make the down convert trough software.
Question 02:
Will the Ultrastudio 4K accelerate MXF hardware decoding? Or that is only the GPU work?
Thank you all for the help.
