audio delay in PP CC with Ultrasutio 4K is ''backwards''….very dumb…any workaround ?
Anhtu Vu
on Dec 17, 2015 at 4:27:25 am
When i use the Ultrastudio 4K and PP CC 2015, the audio playback is ahead of 50ms, which is about 1,25 frame (reference frame rate is 23.976).
The audio offset in Premiere will pull the audio ahead even more, this is so odd as audio offset should always delay the sound to compensate for the latency caused by monitors.
The video offset won't has no effect.
I'm on a cylinder Mac Pro, OS X 10.9.5, latest Black Magic Video desktop, Audio/video playback is set to Black Magic.
I use the Sync One 2 to measure the latency between audio and video. It's very accurate, up to 1/100 ms.
