Hyperdeck Studio 4K Heat problem
Nate Stephens
on May 13, 2014 at 2:45:31 am
Hey folks, does the Hyperdeck Studio 4K have a known heat problem. I have it mounted above my Studio converter in a 6 unit rack case. The slot#1 SSD when just turned on and still cold will go into record, it does recognize the disc and records for about 16 minutes then you get the no disc message and recording stops. You can take that SSD and put it in slot 2 and hit record and everything is great.
Just asking if this is a known issue.
FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
Write for the Edit, Shoot for the Edit, Edit.....KISS Principle
