Connection Question
Manny Rothman
Connection Question
on Dec 18, 2013 at 9:27:58 pm
Hello,
I was thinking about getting both the DeckLink Mini Monitor Card & the HDLink Pro DVI. Would the following setup make any sense? DeckLink Mini Monitor Card (Installed in Mac Pro 2009) --SDI MALE/MALE CABLE--> HDLink Pro DVI --DVI CABLE--> EIZO CG 210 Monitor. The only concern is that BMG said that they have only tested on larger monitors. Here is the link to the monitors specs: http://reviews.cnet.com/lcd-monitors/eizo-coloredge-cg210-lcd/4507-3174_7-3...
Do you think that this setup will work correctly, even due to the monitors odd native resolution?
Manny Rothman
