HyperDeck 2 cross-conversion?
Brad Bussé
on Nov 14, 2013 at 1:17:50 am
Can the HyperDeck 2 cross-convert 1080p60 to 720p30, or even just record half the frames--1080p60 input but record as 1080p30?
Glenn Sakatch
Re: HyperDeck 2 cross-conversion?
on Nov 14, 2013 at 7:38:28 pm
No, you don't set up frame rates like you might on a more traditional deck. It records and plays back frame rates based on the signal being fed into the system.
Glenn
Brad Bussé
on Nov 21, 2013 at 6:13:02 pm
Are there any singular mini converters out there which convert frame rates with HDMI in, preferably one that can run with a standard battery mount?
